moonnightingale
Full Member level 6
Can any body tell me free software in which i can write assembly language commands and practice it
thanks
thanks
DoraSzasz said:Hello!
You can simply use TASM with TLINK. I attached these programs here.
You must simply run these two files and the start a cmd from RUN option of your Windows and then change the directory where your tasm and tlink are saved.
You must write your assembly language code in Notepad for example and simply save it with .asm extension. The file must be saved in the same directory where the tasm and tlink are
For running the code, you must write into the cmd, after you change the directory where the .asm ,tasm and tlink are, the following commands:
tasm [the_name_of_your_file].asm
tlink [the_name_of_your_file]
[the_name_of_your_file].exe
Please let me know if it helps you!
