I need Matlab codes for Antenna design
TI-89
Junior Member level 1
matlab antenna
Such as
Impedance vs Frequency
Directivity pattern
Elevation pattern
Radiation impedance vs. wavelength
Others
eelinker
Full Member level 5
PERSIA
antenna design using matlab
it depends completely to the antenna and the parameter you want. there are a lot of matlab programs at mathwork site you can use
Regards
shahid78
Full Member level 5
antenna matlab code
this link is not working .
h**p://www.ece.wpi.edu/books/aemm/index
This is the site of Makarov's book about Antenna and EM modelling with Matlab.
can anyone post the new link for this book.
thanks
kleinesmurf69
Member level 5
antenna design in matlab
hello
I am not sure it's the same material covered in the book. it seems they're working on a new related em analysis with matlab project, see: **broken link removed**
best regards
smithchart
Member level 5
antenna array matlab code
The working link to the codes should be:
More information about the ebook itself:
Best regards,
KhangKhang
Member level 2
rotman lens antenna design using matlab
this is another site that contents so many Matlab codes about ur requirements!
h**p://ece.rutgers.edu/~orfanidi/ewa
I also feel glad to send u this pdf book if anyone need. Its name is ELECTROMAGNETIC WAVES AND ANTENNAS - Sophocles J.Orfanidis
simon yong
Newbie level 5
adaptive antenna matlab code
manoelleoemi said:
you can download in
rapidshare.de/files/22596605/Mahafza__Bassem_R._-_Radar_Systems_Analysis_and_Design_Using_MatLab__CRC_Press_.rar
i cant download from it.
is it the link still function?
hope can help to get this
