I need a program for PIC18f4520...
mohideen
Member level 2
Hi all,
I am asked to count from 00-99 in the 7 segment led...
I need a program for this function...
Thanks.
with 74HC595 (see datasheet for pinout)
Your Config,Picmicro,var,etc....
Dim chif1 as byte
Dim chif2 as byte
dim 7seg1 as byte
dim 7seg2 as byte
dim x as byte
Data var PORTX.X
Clock var PORTX.X
Latch var PORTX.X
SHOut Data,Clock,msbfirst,[0,0,0] ' clear
PulsOut Latch,1
DelayMS 1
PulsOut Latch,1
DelayMS 1
MAIN:
For x = 0 To 99
chif1 = Dig temp ,1
chif2 = Dig temp ,2
7seg1 = LookUp chif1 , [63,6,91,79,102,109,125,7,127,111]
7seg2 = LookUp chif2 , [63,6,91,79,102,109,125,7,127,111]
SHOut Data,Clock,msbfirst,[7seg2,7seg1]
PulsOut Latch,1
DelayMS 1
PulsOut Latch,1
DelayMS 100
Next
GoTo Main
;latch = pin12 on HC595
;clock = pin11 " "
;data = pin14 " "
hope this help :grin:
