Thanks again. I searched for rational test realtime. But i have not got proper information.
Does it support for freescale microcontrollers?
Does rational test realtime requires any tool (H/W tool) to interface with our application board (ECU) to perform dynamic analysis?
Do you have any net links for this?
Please help me in rational test realtime. Please comment, it will be very helpful to me.
For test realtime and rt tester u ve 2 port the tool 2 ur platform: compiler and os.
I ve ported this tool 6 times to run on simulators or actual boards. Ports incorporated ucos-ii and embedded linux. I used serial, network interface, or board debugger as communication link between tool on pc and ur application on board.
Amr
Thanx... From where u got this tool? Does it available for evaluation purpose? Also i am not using any os. mine is simple C source code. So please elaborate me all the process in details.
Well, Test real-time runs on your pc. When u write a target deployment board for ur board, you should decide how the tool will talk to the baord. I used serial, ethernet, and jtag before.
