I have doubt in PIC16f1527 baud rate formula
ragav4456
Full Member level 4
Hi friends
I have doubt in UART baudrate formula
SYNC=BRGH=BRG16=0, formula FOSC/[64(n+1)]
SYNC=BRG16=0,BRGH=1, formula FOSC/[16(n+1)]
in my program SYNC=0;BRG16=1;BRGH=1;
can i use this formula
SYNC=0;BRGH=BRG16=1, formula FOSC/[4(n+1)]
Yes, in fact that is the formula you have to use. Just refer to the table in the datasheet:
Hope this helps.
Tahmid.
kindly check the program
How to change the formula?
#include <htc.h>
#include "sci.h"
unsigned int uiRS232Error = 0;
unsigned char sci_Init(unsigned long int baud, unsigned char ninebits)
	int X;
	unsigned long tmp;
	uiRS232Error = 0;
	tmp = 16UL * baud;
	X = (int)(FOSC/tmp) - 1;
	if((X>255) || (X<0))
		tmp = 64UL * baud;
			return 1;
		else
			TX1STAbits.BRGH = 0;	/* low baud rate */
	else
	TX1STAbits.BRGH = 1;	/* high baud rate */
	SPBRG = X;	/* set the baud rate */
        BAUD1CONbits.BRG16=1;
	BAUD1CONbits.ABDOVF=0;
	BAUD1CONbits.RCIDL=0;
	BAUD1CONbits.SCKP=0;
	BAUD1CONbits.WUE=0;
	BAUD1CONbits.ABDEN=1;
	TX1STAbits.SYNC = 0;           /* asynchronous */
	TX1STAbits.SENDB = 0;
	RC1STAbits.SPEN = 1;	/* enable serial port pins */
	RC1STAbits.CREN = 1;	/* enable reception */
	RC1STAbits.SREN = 0;	/* no effect */
	PIE1bits.TX1IE = 1;	/* disable tx interrupts */
	PIE1bits.RC1IE = 1;	/* disable rx interrupts */
	TX1STAbits.TX9  = ninebits?1:0;	/* 8- or 9-bit transmission */
	RC1STAbits.RX9  = ninebits?1:0;	/* 8- or 9-bit reception */
	RC2STAbits.ADDEN=0;
	TX1STAbits.TXEN = 1;	/* enable the transmitter */
	PIR1bits.TX1IF = 0;	/* enable tx interrupts */
	PIR1bits.RC1IF = 0; /* enable rx flag */
	return 0;
void sci_PutByte(unsigned char byte)
{	unsigned long ulICnt=0;
	uiRS232Error = 0;
	while(!PIR1bits.TX1IF && ulICnt < WAIT_TICK_MAX)
	{	ulICnt++;
	TX1REG = byte;
	if(ulICnt >= WAIT_TICK_MAX)
	{	uiRS232Error = 1;
	return;
unsigned char sci_GetByte(void)
	uiRS232Error = 0;
	while(!PIR1bits.RC1IF && ulICnt < WAIT_TICK_MAX)
	{	ulICnt++;
	sci_CheckOERR();
	{	uiRS232Error = 1;
	return RC1REG;	/* RXD9 and FERR are gone now */
unsigned char sci_CheckOERR(void)
	if(RC1STAbits.OERR)
		RC1STAbits.CREN = 0;
		return 1;
	return 0;
#define sci_PutNinth(bitnine)	(TX9D = bitnine?1:0;)
unsigned char sci_GetNinth(void)
	while(!PIR1bits.RC1IF)
		continue;
	return RC1STAbits.RX9D;
unsigned char sci_GetFERR(void)
		continue;
	return RC1STAbits.FERR;
