I can't simulate with MODELSIM
fuevarde
Junior Member level 3
San Jose, Costa Rica
I download ModelSIM; and Xilinx ISE from https://www.xilinx.com/
I install Xilinx ISE and after ModelSIM...
I create a new project for Verilog...
But when i try to simulate a testbench waveform of a *.v file...
Not simulator appear???
If somebody knows how to fix that problem, please help me....
Is a urgent situation... :D
Added after 1 minutes:
By the way, i Think implement my digital design in a Spartan 3 FPGA...
I dont know what i do wrong!!!!
Please help....
Re: I can simulate with MODELSIM
read this pdf.
then u can work on MODELSIM
try below coomand
vlib work
vlog testbench.v
vsim test_bench_module_name
run -all
You must create a file a new TESTBENCH file... after you must open Testbench generator ... an create for testbench waveform... pressing on testbench file... you can see Varius modelsim simulation
if you need a Functional simulation press first Modelsim simulation
if you need a synthesys simulation press the third simulation
You can do, All operations on Xilinx ISE... with out write some code...
Re: I can´t simulate with MODELSIM
I know how to make a good Verilog design,
for high frecuency digital applications, etc...
And how to make the testbench waveform, but all that in Xilinx ISE v6...
Now Xilinx ISE have a new version and ModelSIM too,
and i can´t do magic like in ISE v6!!!!
I don´t know maybe my installaing is wrong,
or my PC doesn´t support that new version....
I going to be crazy.... :cry:
Now, I really hate Xilinx....
I think that Xilinx and ModelSIM are like a virus in my PC....
I can't be happy if i try to synthesis a project...
My PC crash down, and ModelSIM is wrost...
I just use that programs because they are free...
But, 2 GB installation is too much space in my HDD...
Is like a terrorist atack for PC's....
install it over again
or try another free simulator online
i guess it is just a problem with installation
try it on another friend's PC for instance
Hello there,
I hope while u created ur project, u did specify the simulator as Modelsim, SE XE or whatever version u have, And i hope u have proper licence from modelsim as well, ie the starter edition licence or the hardware lock drivers properly intalled and so on...
Then i again hope that u have included the testbench as "for simluation"
Then i hope from the action menu , u have selected behavioural simulation,
Then u will be able to see the test ebnch in the sources list in the project explorer, and in the process explorer, u wil see the simulation options..and there if u have selected modelsim simulator, u will see the "Modelsim" or Xilinx ISE as the option
Please dont feel offended if u r expert level is above all these and u have followed all the above steps.. Its just that i cant judge or try to judge u r expertise level from this distance , and can only follow the basic step by step confirmation...
If all these things are done and u r absolutely sure that there is no probs with ur source testbench and the other source files, we can suspect ur installation.
do u have the license? u must download the license first and save it together with the modelsim file.
