I cannot access the parallel ports under XP
khalid_Hussein
Newbie level 1
xp direct access parallel port
I cannot access the parallel ports (like the parallel printer ports) using Microsoft Visual C++ 6.0 under Windows XP. Is there a solution for this problem?
A.Anand Srinivasan
Advanced Member level 5
India
inpout32.dll +xp+parallel
for security reasons windows XP doesn't allow the parallel port by users... if you have a urgent need try some other OS... windows 98 or linux.... linux has manuals specifying the port addresses and their usage....
MNomanA
Member level 3
access port in xp
Use "Userport" driver ....... u can find it free.....
echo47
USA
dll to access parallel and serial port on xp
This is a very common question. You can search EDAboard for previous discussions.
Here's a helpful web page: "Parallel Port Central"
https://www.lvr.com/parport.htm
I've had good luck with PortTalk.
raghuram_msc
Full Member level 1
cannot directly access to printer port
Hi..khalid,
Xp does not allow direct access to parallal ports (for that matter serial ports also!!!) what i did and u could also do is :-
1. Either write ur own .dll s and let it work as an interface, between "you" and the "Ports"...!
2. or better still use advaced platforms like VC++ ,or .NET or any others and use the inbuilt functions directly. here you need to defin "classes".The advantage here is your program shall work independent of the OS in question.
I may help if you letme know what application you are designing..!!
All the best ...!!
Bye,
Sai
Lance_RFdude.com
Member level 3
Rochester, NY
xp cannot see ports
I've used both porttalk (beyondlogic) and winio (??) -- liked winio better in the long run. Just google these.
-Lance
Kurniawan
Junior Member level 1
can not directly access to printer port xp
You can use delphi as program maker and get the component paralel port
armess
Member level 3
release in use com ports on xp
Hi can u all tell me if i can use C++ or VB6.0 to use parallel port of my PC having XP, to control a unipolar stepper motor.
Added after 5 minutes:
Motor has a torque of 18kgcm and requires a current of 2 amps per phase.
mezo
Member level 5
Egypt
parallel prot vb6.0 windows xp
I don't know very much about stepper motor , but i 'm going to tell you how to control the parallel port using C++ under Windows environment .
you can use these instruction : -
outp, outw .
if you want to know the prototype of these instruction use the help of the C++ version . search for out instruction .
you only will need to know the number of your PC Parallel port . you can do this from the device manager - ports Tab . you 'll find it in name of LPT1 or LPT2 . it is usually with the number 3F8H .
you don't need win32 file or any inpout.dll or inpout32.dll , that easy .
if you need more help send me .
simon111
import inpout32 dll in visual c++ 2008
try winio, it is a good tool to slove this issue.
kmougiakos
access to lpt port under windows xp
Inpout32.dll will solve your problem. Just google it and you ll find example code in VB that teaches you how simple is to use it...
anjosoviaj
Member level 1
inpout32 vbscript
hi ,
i'm doing a project that requires parallel port communication in C#. On googling, i found that this can be done using the inpout32.dll. So i downloaded it and placed it in the system32 folder of Windows.But i'm not able to use it in the program. It is showing a missing library reference or assembly directive.
I'm not able to add it to the references.It is showing error.
Is any kind of registry problems associated with this dll??
please help..
gwatson
Newbie level 1
Canada
access to lpt port xp
An online article over at the Code Project might help:
I/O Ports Uncensored - 1 - Controlling LEDs (Light Emiting Diodes) with Parallel Port
By Levent Saltuklaroglu
The source shows an example import statement for inpout32.dll.
