I am making a simulation of a PWM circuit on Pspice , I need some help.
Mrkilic27
Junior Member level 3
Hello,
This is the circuit: timer.jpg
What must be the tOpen and tClose values? and What must be Voff,VAmpl and FreQ values of V3 ..
Thanks for help
Voff: IS the offset Voltage of sine source. if you are simulation true AC source, this should be zero
Vamp: Peak amplitude of Sin source. Ex: For 110V line one should put 100*1.414
Freq: Frequency of source
Topen: Simulation time at which switch begins to Open
Tclose: Simulation time at which switch begins to close
If you can share what would you like to achieve by these switches, once can suggest alternatives.
