Jun 24, 2009 #1 C chetan477 Newbie level 6 Joined Jun 24, 2009 Messages 14 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location surat Activity points 1,369 "THERE ARE NO DRC RULE CHECKS in RULE FILE" ANY ONE CAN solve this problem................
Jun 24, 2009 #2 D dinesh hegde Member level 2 Joined Apr 1, 2009 Messages 42 Helped 4 Reputation 8 Reaction score 3 Trophy points 1,288 Activity points 1,528 Re: I am getting error in IC FLOW layout DRC checking....... Which tool you are using for checking DRC? Regards, Dinesh
Jun 24, 2009 #3 C chetan477 Newbie level 6 Joined Jun 24, 2009 Messages 14 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location surat Activity points 1,369 Re: I am getting error in IC FLOW layout DRC checking....... Hi........ I am new in tools for making Layout. can u suggest any tutorial to study whole flow till fabrication? I am using UMC library and making layout in Mentor Graphics+IC Flow. Regards
Jun 30, 2009 #4 G Goldeneagle Member level 2 Joined May 28, 2007 Messages 43 Helped 8 Reputation 16 Reaction score 3 Trophy points 1,288 Location Electronic City !! :-) Activity points 1,520 Re: I am getting error in IC FLOW layout DRC checking....... For the ASIC flow you can refer : **broken link removed** For the DRC .. check the log file and see if the path for the rule file is set properly.. and if it is accessing the needed technology file.
