Hspice error: xsram has 34 nodes, sram has 60 nodes
etat2004
Newbie level 1
hspice error
**error** xsram has 34 nodes
sram has 60 nodes
help me
thank you
advaita
Junior Member level 3
Re: hspice error
Hi
May be the error is because there are different number of nodes in the subcircuit definition and instantiation of sram.
kumi
Newbie level 6
hspice error
I think it's means the subcircuit "sram" you defined have 60 nodes.but when you call the subcircuit.you only define the 34 node.
the syntax of subcircuit definition is :
.subckt CircuitName node1 node2 ......noden
.ends
the syntax of call the subcircuit is:
Xn node1 node2 .....noden SubcktName
That's means the number of the node you call a subciruit must same as the subcircuit definition.
paulux
Re: hspice error
Or you attached the wrong subcircuit???
paladinzlp
Full Member level 2
hspice error
hai
It is a call subcircuit problem. You can check the netlist as kumi saying.
I hope that perhaps can help!
