How to write memory module in VHDL?
V
Member level 3
I am new in VHDL.
I want to know how to write a memory module, I don't have any idea on coding the memory module by VHDL.
Memory module what i mean is, it is used for save a standard length of the incoming signal, and also the signal should be on hold, during they are saving in the memory.
thank you very much.
vhdl memory module
What memory u want to use? A FIFO, shift register...
What does your data look like? serial or parallel data.
How fast is the data?
Take a look into the guides from the FPGA vendor u want to implement your design. There you get information how to infer your memory in vhdl.
e.g.: Xilinx: https://www.xilinx.com/support/sw_manuals/xilinx7/download/lib.zip
what does a memory module look like
which tools r u using?
templates in the tool will give an idea abt modelling a ram or rom or shift register using vhdl.
else, u plz detail ur requirement.
ur explanation was not clear in making a picture for ur requirement.
tony andonie, baltimore
you want to write a model or a module?
Normally RAM/ROM for digital designer is a
hard-macro , so you need to do is write a ram/rom controller,unless you want to write a model to test your controller.
if you just want to test in FPGA, you can use their IP(LPM_RAM,LPM_ROM,dp_ram... for @ltera)
what does the memory module look like
Based on what you said, here is the answer:
Below is a "RAM" and a "RAM_TB" written in VHDL. Copy it, understand it and simulated. Let me know if you have anymore questions.
-- ram.vhd
-- writing data to the ram at a certain address and reading back the
-- same data from the same address
-- Design Engineer: Tony Andonie
-- Start date: June 28, 2002
-- Revision dates:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ram is
port (
data_in : in unsigned(8 - 1 downto 0); -- 8 bit data
address : in unsigned(8 - 1 downto 0):= (others => '0'); -- 8 bit add
we : in std_logic; -- write enable
data_out : out unsigned(8 - 1 downto 0)
end ram ;
architecture behav of ram is
type mem_type is array (2**8 downto 0) of unsigned(8 - 1 downto 0);
signal mem : mem_type;
begin
memory : process (we,address,mem,data_in)
begin
if (we = '1') then
mem(to_integer(address)) <= data_in; -- write
end if ;
data_out <= mem(to_integer(address)); -- read
end process memory;
end behav;
-- ram_tb.vhd
-- this file will test the ram
-- start date:
-- revision dates:
library ieee;
entity tb_ram is
end tb_ram;
architecture behav of tb_ram is
component ram
port(
data_in : in unsigned ( 8 - 1 downto 0 );
address : in unsigned ( 8 - 1 downto 0 );
we : in std_logic ;
data_out : out unsigned ( 8 - 1 downto 0 )
end component;
constant period : time := 10 ns;
signal clk : std_logic;
signal w_data_in : unsigned ( 8 - 1 downto 0 );
signal w_address : unsigned ( 8 - 1 downto 0 );
signal w_we : std_logic ;
signal w_data_out : unsigned ( 8 - 1 downto 0 );
begin
u1 : ram port map (
data_in => w_data_in,
address => w_address,
we => w_we,
data_out => w_data_out
clk <= not clk after period/2;
stimuli : process
begin
w_data_in <= "00000000";
w_address <= "00000010";
w_we <= '1';
wait for period;
wait;
end process stimuli;
end behav;
memory module design
Thank you all of you~
I want to ask andonie
what the following statements means:
Really thanks for your kindly help.
Re: memory module
V,
Do the following:
1) Take the below updated Designs "ram.vhd" and "ram_tb.vhd" compile them and simulate them using Modelsim
2) type mem_type is array (2**8 downto 0) of unsigned(7 downto 0);
a) (2**8 downto 0) means that 2^8 which is 256 ram deep
b) (7 downto 0) means that the ram is 8 bits wide
c) mem_type means you declaring the memory
3) mem(to_integer(address)) <= data_in;
it means that you are writing data_in at a certain address and that address is only integer numbers. " see the testbench" for details. if you have furthur questions feel free to call me after 7:00 pm at (619) 206-6183
Good luck
-- Company: N/A
-- Project: ram
-- File Name: ram.vhd
-- Engineer: Tony Andonie
-- Start Date: April 8, 2005
-- Revision Dates:
-- Description: writing data to the ram at a certain address and reading back the
library ieee;
entity ram is
port (
data_in : in unsigned(7 downto 0);
address : in unsigned(7 downto 0);
we : in std_logic;
data_out : out unsigned(7 downto 0)
end ram;
architecture behv of ram is
begin
memory: process (we,address,mem,data_in)
begin
if (we = '1') then
end if ;
end process memory;
end behv;
-- Company: N/A
-- Project: ram
-- Revision Dates:
-- Description: ram testbench
library ieee;
entity ram_tb is
end ram_tb;
architecture behv of ram_tb is
component ram
port(
we : in std_logic ;
data_out : out unsigned (7 downto 0)
end component;
signal w_data_in : unsigned(7 downto 0):= (others => '0');
signal w_address : unsigned(7 downto 0):= (others => '0');
signal w_we : std_logic:= '0';
signal w_data_out : unsigned(7 downto 0):= (others => '0');
begin
u1_ram: ram port map (
we => w_we,
main: process
begin
-- write to the ram
-- first cycle
wait for 10 ns;
w_address <= "11000011";
wait for 10 ns;
w_we <= '0';
w_data_in <= "11111111";
wait for 10 ns;
w_we <='1';
wait for 4000 ns;
wait;
end process main;
end behv;
