How to write DC constraint scripts for RGMII IP CORE
tavidu
Member level 1
Member level 1
rgmii waveform
I'v designed RGMII IP CORE
but I really dont know how to write dc constraits script of design compiler, because
RGMII use rising&falling edge of a clock.
Anyone can give me any suggestion?
Thanks
utmseng
Junior Member level 2
AZ
Re: dc scripts of RGMII
Can you describe more on your design's clock waveform? I thought DC's create_clock is able to constraint your design. You can man create_clock to take a closer look.
ami
Member level 3
Member level 3
VN
1. Define input clock.
2. Set_input_delay with respect to rising edge of the clock.
3. Set_input_delay with respect to falling edge of the clock using “-clock_fall” switch.
Use similar rule for output timing constraints.
