If your looking for a quick pulse (say to clear a reg/combinatorial) then your coding the problem incorrectly.. never use gate delays.. there is always ways around it.. just hard to figure out..
I think it's no way to create a pulse in degital ckt,
(use a faster clock is not a pulse)
I think you need a hard-macro
(Delay cell, use spice to calculate the delay to meet your pulse width)
then in verilog:
wire pulse,pulsed,pulse_want;
dly(.out(pulsed), .in(pulse));
assign pulse_want = pulse& ~pulsed;
Your problem is not very clear. If you are having a clock signal and an enable signal which when arrives you must give out exactly one pulse, then, you can use two flips flops clocked by the same clock.
O/p of the first flip flop goes as input to the second and the output of the second goes as I/p clear to the first, take o/p from the o/p of the first flip flop, this will be a single cycle pulse.
Your enable can be any cycle width. Nest pulse will be generated only when enable comes for the second time. Tell me if it is clear ???
