i do not how matlab does it internally.
but it may be something like this.
u have say three stages and each is an LPF.
so when u give an input to the first stage u know it's response which u may feed it to the second and so on and the resulting final result of the last stage may be put in an array in ur verilog or vhdl code and verified.hope i am clear.
this is a matlab generated sample code(not full)
module filter2_tb;
// Parameters
parameter clk_high = 5;
parameter clk_low = 5;
parameter clk_period = 10;
parameter clk_hold = 2;
// Nets
reg clk;
reg clk_enable;
reg reset;
reg signed [15] filter_in;
wire signed [15] filter_out;
integer n; //loop variable
reg signed [15] filter_in_force [0];
reg signed [15] filter_out_expected [0];
// Component Instances
filter2 u_filter2
.clk(clk),
.clk_enable(clk_enable),
.reset(reset),
.filter_in(filter_in),
.filter_out(filter_out)
initial
begin
// Constants
filter_in_force [0] <= 16'h7fff;
filter_in_force [1] <= 16'h7fff;
filter_in_force [2] <= 16'h7fff;
filter_out_expected [0] <= 16'h0000;
filter_out_expected [1] <= 16'h0000;
filter_out_expected [2] <= 16'h0000;
filter_out_expected [3] <= 16'h0000;
end
// Block Statements
always // clk generation
begin : clk_gen
clk <= 1'b 1;
# clk_high;
clk <= 1'b 0;
# clk_low;
end //clk_gen;
initial // reset block
begin : reset_gen
clk_enable <= 1'b1;
reset <= 1'b 1;
# (clk_period*2 + clk_hold);
reset <= 1'b 0;
end //reset_gen;
initial //The main block
begin
# clk_period;
filter_in <= filter_in_force[0];
filter_in <= filter_in_force[1];
# clk_period;
for (n = 0; n<= 4970; n = n + 1)
begin
if (filter_out !== filter_out_expected[n])
$display("ERROR in filter test at time %t : Expected '%h' Actual '%h'", $time, filter_out_expected[n], filter_out);
if (n + 2 <= 4970)
filter_in <= filter_in_force[n + 2];
# (clk_period);
end
$display( "**** Test Complete. ****" );
$stop;
end //filter_in_gen;
endmodule
Added after 37 seconds:
this isnot forthe decimator it's for a bpf butterworth
