how to use ua723 voltage regulate IC ?
jkl99878
Newbie level 3
ua723
Is it possible to make a circuit that can regulate from 2V to 15V.
The datasheet provides circuit diagram that can either regulate
from 2v to 7v or 7v to 35v.
ua723 circuits
The LM723 can be easily used to regulate the output in a wide range of voltages, 2V-to-15V, for example, without changing configuration ..
Data sheets usually cover only basic features ..
In the case of the LM723 regulator you can do it in two ways:
- set the IN(+) to 2V dc by dividing Vref(=7.15V) as shown in the 2-7V example, and feed the output voltage through a potentiometer to IN(-), or ..
- divide the output voltage with fixed resistive voltage divider and feed it to IN(-) and vary reference voltage connected to IN(+) ..
The latter method is used in the following example:
Regards,
IanP
ua723 circuit
Also u can better check the datasheet....
collection ua723 circuits
Here is the Datasheet.
