how to use two 4bit multipliers to make up a 8bit multiplier
red_0220
Junior Member level 1
Hi all,
Could you tell me how to use two 4bit multipliers to make up a 8bit multiplier?
thanks.
ebuddy
Full Member level 3
Re: how to use two 4bit multipliers to make up a 8bit multip
Will it allow AND/OR gates to be part of the soultion.? A good way to find out is to use synthesis tool to do the experiment and see what result it gives you. If synthesis tool can't do it, then it is most likely not doable. Post the result if you find one.
raja.mst
we can do it using 4 4-bit multipliers? and 3 Ripple Carry adders.
red_0220
Can you tell me how to do it?
Thanks.
Added after 1 minutes:
Thanks.
Added after 2 minutes:
To raja.mst
Thanks.
Added after 5 minutes:
Thanks.
kforkarim
Newbie level 1
Hey Raj,
Can you tell us how you implement this?
Thanks
bunalmis
Full Member level 5
Ireland
Same as paper and pencil method.
a,b,c,d are four bits. ab and cd are 8 bit.
ab x cd = (b x d) + (a x d)<<4 + (c x b)<<4 + (a x c)<<8
    red_0220
red_0220
If I want to make up 16 bit multiplier by 4 bit multiplier.
Need Sixteen 4 bit multiplier at least?
thanks
