How to use schematic entry add for Hspice 2003?
odyseus
Cold & Wet Europe!
Hspice schematic entry
Hi all,
I've got a copy of Hspice 2003 but is only netlist entry, is there is simple to use schematic entry add on for this simulator ??
cheers
Ody
Re: Hspice schematic entry
hspice have no schematic, use 0rc@d c@pture or cosmos, then you can create netlist.
I was thinking of something that would work under WinXP ?
What about Ledit ?
You can try to use the Workview which can be used on Window2000/XP
What about Ledit ?
Actually, Sedit is the tool to create Schematics, Ledit is the tool for IC layout
hi gerryhsu,
Is it possible to use hspice as simulation engine for sedit?
Hspice is in a way similar to SmartSpice. I know that smartspice can be integrated with ViewLogic and then use ViewDraw as schematic capture. Does anyone know what is needed to do the integration? How it can be done?
Maybe you can try MYCAD on Windows.
ViewDraw is now part of eProduct Designer from Menter Graphics.
OK, but can smartspice be integrated within viewdraw?
