How to use RTOS and how it can trigger functions or interrupts?
btminzon
Full Member level 2
Brazil
Hi people
I'm new using RTOS. I have questions: First of all, how can i use RTOS? for example, FreeRTOS, or BOS for MSP430, etc... Do i need to use more than one firmware running in uProcessor, or just one running under RTOS? in case using one software (firmware), how RTOS can trigger my functions, or interrupts? its very obscure to me untill now...Thanks a lot your help
beste regards
rtos questions
You build your program with the rtos.
Your program may consist of several tasks or functions.
The rtos manages the switching between the tasks and the communications between them.
    btminzon
general rtos concepts
you could have sw interrupts, like timer, and hw interrupt, like press a button.
question of rtos concepts
Hi
U can read SALVO user manual (Ch2), it very useful, and so easy, it is describe the behavior of the RTOS (general RTOS not only SALVO) and how managing the overall system, and finally a case study.
i think it will be useful for u
best regards
rtos question
eng_ahmed22 said:
Hi
best regards
How can we get the above manual?
freertos pdf api
Hi
You can read scmRTOS user manual (for old version)
best rtos books
RTOS as name suggest is a real time operating system. Apart from its real time nature, it functions as normal OS(Windows,Linux).
OS is a abstraction to the low level system functionality. Depends on the OS architecture you can create a task,process,thread.
Lets take a hypothetical example, say you have RTOS X, and it supports only one process(task), and supports n threads. Now you can write a program which uses the API provided by OS to perform some operation. Compile it, link it with RTOS and burn in on the hardware,
Now there is only one user process is running and thread you have created, But depends on the architecture of the OS, there may be some other system processes running to do memory managment, thread management, interrupt handling etc.
question for rtos
A good starting point to understand how the things work is FreeRTOS.
Go to www.freertos.org page and have a look at the tutes.
questons on rtos
start with ucos2 book by jean labrosse.
everything abt rtos will be there and explined in easy way
scmrtos_v2.pdf
yeah, uCOS -II by Jean J Labrosse is a very good book. RTOS concepts by Quing Li is another very good book for starters it is an asset.
