I'm trying to write a c code for a macro to generate a differential input stage. I read the L-Edit manual for UPI, but I don't know how to merge several boxes on the same layer.
Example: I have 3 boxes of poly which overlaps. Which is the syntax for doing this?
OK...I shall answer myself at this question. There was a silly mistake. The syntax is:
LSelection selected;
LSelection_SelectAll(); // here you can select only one type of layer - see
Selection Functions
selected = LSelection_GetList();
LSelection_Merge(); LDisplay_Refresh();
The problem was that I didn't write the last line and the display of the layout was not refreshed. After I added this line, the merge operation was shown.
The layout created by macro is flatten.
If you just layout the diff input pair, i think you can insert mos/bjt cell that will more usefull.
And you can create a tcell with parameter what you want, it will easy and usefull.
---------- Post added at 02:40 AM ---------- Previous post was at 02:35 AM ----------
i am a layout engineer, and i have some time do the upi for ledit. here is my email:dabing.lee@gmail.com.
I am very happy for exchange experience with you.
