shahare.sumedh
Junior Member level 2
- Joined
- Nov 15, 2010
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- chinchwad, pune
- Activity points
- 1,439
when i join the input of l293d, to out pins of 7404,, the motor starts running ,,
even if i dont give any input to the inverter gates of 7404
what is bypassing?? can you tell me how to bypass 7404 inverter??.....
can u give me a diagram please......
the data coming out from ht12d needs to be inverted using 7404 and then it is to be given to l293d
Could you explain this a bit in more detail..How?..hi ...don't invert the data from ht12d, it will invert the behavior of motor. :-D
i have tested motor driver ic separately,,,, according the diagram,,
i have connected all the pins of l293d except the data input pins as shown in diagram,, when i give (+) positive current to pins 2, 7, 10, 15, the motors run
but when i supply (-) negative current to the pins the motors are unaffected,,
so according to my information, the input pins of l293d need (+)voltage to run the motors.... and the data output pins of ht12d decoder ic supply (-) current,,, so to invert
this data of ht12d 7404 inverter ic is needed,,,,, so i want to know how to bypass 7404 ic...... please help..
Since the encoder/decoder pair used here works on negative logic, the decoded signals are fed to an inverter (NOT gate) IC 74LS04. The proper (inverted) signals are then supplied to L293D. so i want to know how the signals are fed to 7404,,,,,, i have tried doing it,, but it is not working.. please help...
