How to turn off power supply with a switch
ebuddy
Full Member level 3
I have an IC on PCB board. I'll need to put a switch to turn off the +5V power to the IC from time to time. However, I only have "normally-off" switch in hand. Anyone knows how to do this? Thanks.
You'll need some additional circuitry. Something to "invert" your normally=off switch. So when your switch is OFF, the circuit (power to IC) is ON, and vice-versa. A simple BJT/ FET/ MOSFET/ Relay comes to mind. Take our pick & work it out.
cheers!
Dear ebuddy
Hi
It depends on how much is your required current through switch and how much should be the frequency of turning off and turning on .
Best Wishes
Goldsmith
To use a single switch he may use the bistable flip-flop which can be toggled between states with a single push button.
See some details here:
http://www.bowdenshobbycircuits.info/page9.htm
By the other hand we can change the relay by a P channel MOSFET. :grin:
Dear ebuddy
Hi
Best Wishes
Goldsmith
The current is several mA, and frequency of switch is very slow (manual switch). Thanks.
Nice overkill mister_rf ... LoL !! :p
Here's a simpler one. Just chose a relay which works with 5v or whatever your Vcc is.
You don’ t get it… I understand there's push-to-make switch available, that returns to its normally open (off) position when you release the button, so using that diagram you may keep a closed circuit after pressing the button and disconnect the load for a second push, and that's similar to a toggle switch. :roll:
I'm not quite sure the question asker wants a 'toggle' switch. Does he ? He just wants to disconnect an IC's power when he presses a switch.
The principle used here is know as the "KISS".
Maybe you've heard/ read of it ?
cheers!
Hi again
You can use a simple opto coupler for this aim . or a simple BJT . in series with ground path .
Best Wishes
Goldsmith
Buy. Buy one switch as per your requirement.
ebuddy,
Learn and get idea from all the posts. Also consider time and money required to make changes to your normally off switch.
Consider feasibility for your case.
