How to transfer data to a server over GPRS connection ??
formate_mind
Newbie level 2
i want to ask u about a problem i get in using an M2M application using GPRS MODULE
I am using NOKIA N12 GSM/GPRS module
my target application is to use this module to transfer data from micro-controller to a server on NET or send this data Via Email
i am working now on how to transfer data to SERVER, but i got some problems:
i have established a GPRS connection
but i don't know how to transfer data to the server ????
could anyone could help me plz???
omore
Member level 4
Argentina
First some questions.
Do U have a server que you can see what U send ? If no, pls, let me know and I can send u an application to run on a pc.
Once your server lisnten to the port you specify, u can use an AT command by which U specify the number of bytes you are going to send. Then you type the characters and when the count is finished, the packet is sended.
formate_mind
Newbie level 2
thanks for ur reply
but i haven't got a server
could u send me the application plz
thanks again
omore
Member level 4
Argentina
I used it and works OK. SIMCOM brings it to make test but should work with your module.
Best regards
Added after 16 minutes:
I WAS TRYING TO DOWNLOAD A FILE THAT I´VE DOWNLOADED FROM EDABOARD.
GO TO THE FOLLOWING LING AND DOWNLOAD THE FILE SERVER.ZIP
