How to transfer antenna parameter from layout window to schematic window?
ebi_hassani
Newbie level 2
Hello every one
I need to simulate active microstrip antenna by use ADS ,but I couldn't transfer antenna parameter from layout window to shematic window.
do you know?
thank you.
ADS PROBLEM
thank you for notice.
I also want to add coax probe to microstrip antenna
but I don't know what am I doing for attach port to
antenna for exitation.
do you know?
best regard
Re: ADS PROBLEM
You can at first parameterize all conductive patches but not other passive nor active elements in the layout design. then you can convert it to a block with some ports. afterwards you must import it in the schematic and add other active or passive elements.
