How to test a bilateral Sidac?
seety1981
Junior Member level 1
Hii...
HAve anybody here knows how to test the functional of a bilateral Sidac?
Regards,
Seety
sidac parameter
A SIDAC is realy a thyristor. Thus, it will trigger at a certain voltage and remain in conduction until the current through it drops below the hold-up current.
To test, apply an increasing voltage to the SIDAC, through a resistor. At a certain voltage the SIDAC will turn on. This is a parameter that you need, so measure it carefully.
The current limiting resistor should be high enough such that the resulting current through the SIDAC is lower than the maximum continuous current, but low enough to ensure the current will be higher than the hold-up current, so the SIDAC will stay on.
Once the SIDAC has triggerred, measure the current through it and increase the series resistor until the SIDAC turns off. The current at which the SIDAC turns off is the hold-up current.
Repeat these tests for the other polarity.
Re: How to test SIDAC?
Hi ,
While testing in PCB we found that by reversing the polarity position for SIDAC , it is not working. But other SIDAC is working fine .
What could be the problem with the not working SIDAC. Please advice
