I am trying to find a way to terminate dummy ports without using a port due to the fact that there are no space to add a ports of the dummy between the main ports at the edge as I describe in the attached picture. Do you have any idea?
Re: How to terminate dummy ports without the edge?
Terminate the dummy ports with 50 ohm impedance.(Calculate the width required for the dummy port to have 50 ohm impedance)
But I dont have enough space at the edge to put the ports for the terminators(attached picture)
