MScofield
Newbie level 5
Hi all,
Which is the best way to supply the 4V/2A voltage/current to the sim300 module, if you don't want to use a battery.
One can use a voltage regulator like LM317 or a cheap solution like a zener diode between the main voltage and the module VBAT pin.
Im my oppinion, the LM317 does not fit for the solution because it can supply 1.5A, and the zener solution does not give a estable current source.
What is your suggestion?
Thanks in advance.
Thanks in advance.
