[SOLVED] how to store received stream of serial data? (PIC16F877A)
vinodstanur
Advanced Member level 3
Kerala (INDIA)
Hi, now i just started learning USART in PIC. I can now read serial data from RCREG register of PIC16F877A. But now i want to store successive keyboard pressings (in hyperterminal) in 30 variables.
If i press keyboard then corresponding ascii is loaded in RCREG and i can save it in a variable. Upto that its working...
NOW, PLS give me a small idea how to store a 10 successive keypress in 10 variables...
As Embedded Partner said, use an array of characters with size equal to the number of characters you want to receive and, a pointer to that array.
Here's a code for a function that receive a stream of characters from the hyper terminal.
char *Receive_MSG(char *String, unsigned short int MSG_Length)
	unsigned short int Index = 0;	// Message Index
	while(Index < MSG_Length)
		String[Index] = Receive_Byte();
		if(String[Index] != 13 && String[Index] != 10)
			String[Index + 1] = '\0';		// Set the next character to NULL
			Index++;
		else
			break;
	return String;
Hi vinodstanur,
If you use C, above mentioned arrays and pointers can be used easily for the purpose.
If you use assembly, use Indirect-addressing with INDF and FSR registers (see datasheet for details).
Thanks
for serial communications the best approach is to use circular FIFO - search in the forum, there was already some discussion about this. Using simply an array is not very good approach - you'll find out that during reading if write event occurs you'll get conflicts. Make it professional - use FIFO
