nesta
Junior Member level 2
Hi VhdlExperts,
I am in the process of learning vhdl.
I am having problem with undefined signal during simulation, plz help. Below is the code and problem mentioned.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity hd2_slc is
port(
b : IN std_logic_vector(5 downto 0);
c_out0 : OUT std_logic_vector(2 downto 0)
end hd2_slc;
architecture hh of hd2_slc is
COMPONENT node
port(
I : IN std_logic_vector(2 downto 0);
Ou : OUT std_logic_vector(2 downto 0)
end component;
signal c_0 :std_logic_vector(2 downto 0) ;
begin
UU_0: node port map (
I(0) => b(5),
I(1) => b(4),
I(2) => b(2),
Ou => c_0 -- This give me undefined signal (U)
-- Ou => c_out0 This one works.
end hh;
Why does the above code show Undefined signal (U) in the simulation for c_out vector. i know that if i port map Ou => c_out0 it works well.
But my requirement is to use a local signal and after some processing assign it to c_out0 vector.
Kindly suggest what am i doing wrong, how to use a different signal to port map with the Ou vector.
Thanks,
Nesta
library IEEE;
entity hd2_slc is
port(
end hd2_slc;
COMPONENT node
port(
end component;
begin
I(0) => b(5),
I(1) => b(4),
I(2) => b(2),
end hh;
Thanks,
Nesta
