[SOLVED] How to solve Oscillation.. Old problem
TuAtAu
Jupiital
I want the Blue color Current wave, follow the yellow input voltage signal..
but there is some oscillation.. how to solve.. I try to put some RC to compensate it.. still doesnt work.. how. :-(
Those ringing oscillations start at the same time your pulse starts a positive excursion.
Then the ringing fades. Characteristic of an LC tank circuit.
Do you have any coils in your power supplies? In the waveform generator?
How are you producing 0.6V at right? Is it by means of a high impedance?
There's another possibility. Your positive pulse begins when the op amp sends positive bias to the 2N2222. However notice that no bias current flows. The bias current meets very high resistance at the gate of the mosfet. And the 2N3906 is turned off at that moment.
However it works somewhat (according to your plot) in the sense that the 2N2222 manages to turn on the mosfet, even though the 2N2222 is being operated without current flowing through it.
Then I also notice you put a load in the source leg of the mosfet. With current going through the load, it generates a voltage across it.
Whatever that voltage is, it has the effect of reducing net voltage at the mosfet's gate. (Because an N-mosfet has its gate V referenced to the source terminal.) This has a feedback effect back to the 2N2222, which in turn has a feedback effect to the op amp and its internal transistor.
I think the oscillations result from these feedbacks causing a bouncing effect (ringing) in the biasing current (or should it be called bias voltage?).
I think you can stop the ringing if you install a 1k to 100k ohm resistor from the mosfet gate to zero ground. That should give you more stable operation as the 2N2222 starts to respond to the input pulse.
Reactions: TuAtAu
    TuAtAu
You haven't biased the bipolar transistors so there is a huge deadband - it cannot help ringing. You could try driving the MOSFET directly from the opamp with a series resistor.
Also, why use a 230MHz opamp followed by such slow components?
Keith
Reactions: TuAtAu
    TuAtAu
haha~ i see, the problem is solve after i change to LM7171AIM and output directly drive the mosfet with remove the 2 BJT. Thanks you guys to point out the problem ;)
