bosparra
Junior Member level 1
Kicad errors
I am trying out Kicad for the first time. I've found that once I got my head around the seperate component and footprint libraries it all makes sense. But I've got a couple of issues I can't seem to figure out.
(I can't get the image to show in the right place in this post?)
Firstly, schematic rules check errors:
My PSU circuit looks as follows and the arrow indicates the following error
ErrType(4): Conflict problem between pins. Severity: warning
@ (8.5500 ",1.5500 "): Cmp U1, Pin VO (power_out) connected to
@ (2.6000 ",4.6000 "): Cmp MCU1, Pin 7 (BiDi) (net 28)
(See psu.png)
MCU1, Pin 7 is the AVCC pin, which is connected to VCC as shown below. This is intentional, but I can't figure out how to get rid of the warning.
(See vcc.png)
The second warning says the following:
ErrType(3): Pin connected to some others pins but no pin to drive it
@ (5.6000 ",5.2500 "): Cmp #PWR014, Pin 1 (power_in) not driven (Net 10)
This relates to a switch as shown below, whats up with that?
(See switch.png)
Secondly, the voltage regulator shown in the PSU circuit, remains unconnected in the board. The error I get is something like Module [U1]: Pad [GND] not found and then repeats for the other two pads. I suspect it is because the pin names are incorrect. I made a new footprint with the correct names, but the errors stay the same.
Any help would be appreciated, as I have read just about every tutorial out there and none of them cover the issues I have.
(See psu.png)
(See vcc.png)
(See switch.png)
