Candy8866
Member level 2
Feature:
>> Accuracy:0.1/0.2/0.5
>> 4-20mA/0-5V/0-10V standard input signal
>> 0~100mA/0~500mA/0~1A current signal output
Or 0~1V(max 1A)/0~5V(max 500mA) voltage signal output
>> Input/output isolation(3000VDC)
>> Power supply:12VDC/15VDC/24VDC etc.
>> Between power supply and output signal are non-isolated
>> Standard DIN rail-mounted,industrial temperature : - 45 ~ + 80 deg.C
Application:
>> Industrial signal isolation and amplifier
>> Current signal amplifier or strengthen voltage signal drive capability
>> Electromagnetism valve or proportion valve linearity drivers.
>> Magnistor linearity controller
>> Electromagnetism drive coils or high power load
>> Ground-loop elimination
Description:
This product contains a group of high accuracy isolated amplifier circuit and a power amplifier circuit.It is widely used in current signal or voltage signal drive capability high need situation. Standard DIN rail-mounted,easy to use.
Application:
Description:
