Can some please verify if this is true...
For simulation, instead of writing a regular testbench you would write a psl file for your design and use Modelsim to simulate.
I am very new to this vhdl stuff and have been doing lots of reading but still confuse
If it is true then please provide a simple design with psl so that I can follow through it.
Hey i am not sure of the .psl file...but you can definitely use the .do file to simulate your verilog or vhdl file... the .do files are macros... you must have used the command window in modelsim to force inputs... you have to use the same commands to write that .do file and can simulate it....
What i know is that you can use TCL or DO files ; and i think that PSL files stands for Property Specific Language.
PSL is designed to be used by both formal (mathematical proof) and dynamic (simulation based) methods of checking.
you can have PSL properties directly within your RTL code...or you can have vunits (verification units) in separate files with all the properties gathered up...and these vunits are bound to the design files
thank you all for the response. your effort in trying to help is very much appreciated.
what i am looking for is an example of a simple design plus external psl file (verification unit file) that i can follow through using modelsim.
so basically...two files.
1. design.vhd
2. design_tb.psl
walid,
if you can please upload them. do you have a step by step process of how to simulate a design with a psl file using Modelsim? the simplest the better as i am very new to this vhdl stuff.
salma ali bakr,
thanks for the heads up.
Added after 3 minutes:
this is what i found during my search. the link below has both a design and psl file.
basically i copy/paste both design and psl file and simulate with modelsim but somehow i never see the assertion part/value in modelsim.
what am i missing?
you have to add the assertions to your wave...
you'll find them under your design unit..
and you'll just right click and add them to the wave
they should give you passed or failed...etc
Here it is , but it is some how BIG.
The Instructions are in a file "doit.sh", so if you have linux or Cygwin on windows just use "doit.sh demo" ... otherwise just open the file and u can find the ModleSim Instructions.
Its one of the ModelSim examples so you can find it on Modeltec..../examples/psl/vhdl/
i got it working with psl using modelsim.
but now i got another problem. when i run the simulation i got nothing but red and blue lines in the wave window. this only happens when using psl. with a regular testbench there is a timing diagram. need to work on this.
i have attached 2 files.
one is a design and the other is psl file.
please keep in mind that i am not after the design itself as can be seen from the file.
what i am after is how to simulate the design with a psl file as oppose to the a regular testbench. so therefore...the file is just some very basic stuff.
i am not sure this is the way to do it. it is my first attempt at trying psl and also some what new to vhdl.
so you simulated the psl file
and what happened...? something wrong with the waves..?
i've worked with psl before but never tried to do separate files for the properties
it's always better to embed them in your code, it'll be easier this way to follow up with them...or put them in the test bench...no need to use the vunit even...but it's always good practice to test the untested
i follow those commands and did not get the same result.
mine still shows red and blue lines.
can you clarify what you meant by:
force the signals using the Modelsim GUI...instead of a testbench.
here is how i do mine. maybe i am missing a step somewhere.
1. create a directory
2. save two files to the above directory; design and psl
3. run modelsim, create project/work directory and point to number 1 above.
4. load two files into modelsim
5. compile the design file
6. add all signals to the wave window
7. run those commands
8. press the run button(as shown from the screenshot)
