How to shift the wave by 90 degree?
seemagoyal44
Member level 1
i wann my a waveform to be shifted by 90 degree....what is the method to shift the wave by 90 degree.....with diagram
FANT
Advanced Member level 1
Italy
Re: phase shifter
It depends at which frequency is the signal.
If it is in the low Rf band ( less than 1 MHz ) an OP-Amp will solve the problem; in the mid band ( 1 to 400 MHz ) a piece of cable is good; above 400 MHz a piece of FR4 is good too.
If the signal is broadband ( and you can loos e 3-4 dB ) Mini circuits has power splitters with one out at 90 degrees shift.
Mandi
