How to set length constraint in Altium
Anonymous_Ricky
Advanced Member level 2
India
Hi all,
How can I set tthe length constraint in altium for different buses. I have 6 buses and I want to set the length for each signal in a particular bus to equal lngth with some tolerance.
i am not able to do that Someone kindly help.
Thanks and Regards,
Ricky
its from Altium Designer Training for Schematic Capture and PCB Editing.pdf
Differential Pairs Editor
• You can review and edit Differential Pairs in the
PCB panel by selecting the Differential Pairs
Editor from the drop-down list at the top of the
panel.
• Select the Differential Pair Class you want to
display by clicking on the Differential Pair Class
name. The Differential Pair Designators will then
be listed.
• Click on a Differential Pair name in the
Differential Pair section to show the constituent
nets of the pair, both positive and negative.
• Double-click on a Differential Pair name to edit
the nets associated with the Pair and view the
options.
• Right-click on any Differential Pair Class listing
(Excepting the default class of All Differential
Pairs) and the Object Class Explorer dialog will
open allowing you to modify your Classes.
How to set length constraint in @ltium
Thanks rezasurmar,
but i am talking about a whole bus say for example a data bus of 16 signals and 6 different buses of such type.
Regards,
Ricky
everything is in design rules, length is in submenu highspeed,example add net to netclass and set the min-max length to net. In my pcb desing i used netclass, and set Differential Pair to net and min length. Maybe you wont "Launched from Tools » Interactive Length Tuning". sorry for my poor english
