Dec 8, 2004 #1 J Johnson Advanced Member level 2 Joined Oct 4, 2004 Messages 520 Helped 28 Reputation 56 Reaction score 7 Trophy points 1,298 Activity points 3,613 spectra help routing Spectra: Help is need to route a 32-bit bus on a 16-layer PCB with same shape for all line(as same as possible), also fanout hints?
Dec 14, 2004 #2 I ic2004 Newbie level 5 Joined Dec 14, 2004 Messages 10 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 57 Re: Help PCB Routing Hi, U can search in this site, I remember that about 1 year ago. there are a document for Layout Mainboard P4 of VIA Technology. I think it will be match with your request. Good luck. IC2004
Dec 14, 2004 #3 Y ylscqu Member level 2 Joined Dec 20, 2003 Messages 46 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Activity points 278 Help PCB Routing There is a command Do not make useless posts. Read the rules. Warning. /pisoiu
Dec 14, 2004 #4 H hock Advanced Member level 2 Joined May 28, 2001 Messages 524 Helped 47 Reputation 94 Reaction score 21 Trophy points 1,298 Location India Activity points 3,567 Re: Help PCB Routing this is a very bad repply. dont just say there is a command, if possible give the information regarding the command as well. hock
