how to resolve ports and nets mismatches in calibre lvs
chiranjeevinaidu
Junior Member level 2
Hi ,
I ran calibre lvs .I saw some ports/nets mismatched.
After Transformation:
ports
----layout source
Net GND GND
13 -------
cells :AND1D AND1D
in1:a in1:a
in2:b in2:b
in3:1 in3:GND
In above I just gived example of report file content
and one more thing all instances are passed but ports and nets are mismathed
please give me any suggestion Above error
Looks like in the layout pin in3 is supposed to be connected to GND but is not. Could be a layout issue or layout spice netlist has some issues.
Hi ,
ports
----layout source
Net GND GND
13 -------
cells :AND1D AND1D
in1:a in1:a
in2:b in2:b
in3:1 in3:GND
Check out the in3 both in layout and sch. there is definately some mismatch there
Hi Guys
thanks for replied.
here below images shows mismatched ports/nets...please look at this issue
- - - Updated - - -[/COLOR
From the images i feel that either label layer or pin layer is missing in the layout or its in the inner hierarchy (on the top level). So calibre can not find the ports. try to solve ports error first . then may be net error will be solved automatically.
Try running lvs in the flatened mode
