robert@redcor.ch
Newbie level 1
Hi there,
I am using i sligthly modified c program I found on the net:
Original GitHub Repository
Sometimes I need to reinitialize the modem, however it seems to be blocked.
How can I reset it, preferably using AT commands to a non cmux configuration.
thanks for your time
robert
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 /** * Cmux * Enables GSM 0710 multiplex using n_gsm * * Copyright (C) 2013 - Rtone - Nicolas Le Manchet <nicolaslm@rtone.fr> * * This program is free software: you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation, either version 3 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program. If not, see <http://www.gnu.org/licenses/>. * */ #include <stdlib.h> #include <stdio.h> #include <stdarg.h> #include <string.h> #include <sys/ioctl.h> #include <fcntl.h> #include <termios.h> #include <net/if.h> #include <linux/types.h> #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <unistd.h> #include <err.h> #include <signal.h> /** * gsmmux.h provides n_gsm line dicipline structures and functions. * It should be kept in sync with your kernel release. */ #include "gsmmux.h" /* n_gsm ioctl */ #ifndef N_GSM0710 # define N_GSM0710 21 #endif /* attach a line discipline ioctl */ #ifndef TIOCSETD # define TIOCSETD 0x5423 #endif /* serial port of the modem */ #define SERIAL_PORT "/dev/ttyS1" /* line speed */ #define LINE_SPEED B115200 /* maximum transfert unit (MTU), value in bytes */ #define MTU 512 /** * whether or not to create virtual TTYs for the multiplex * 0 : do not create * 1 : create */ #define CREATE_NODES 1 /* number of virtual TTYs to create (most modems can handle up to 4) */ #define NUM_NODES 4 /* name of the virtual TTYs to create */ #define BASENAME_NODES "/dev/ttyGSM" /* name of the driver, used to get the major number */ #define DRIVER_NAME "gsmtty" /** * whether or not to print debug messages to stderr * 0 : debug off * 1 : debug on */ #define DEBUG 1 /** * whether or not to detach the program from the terminal * 0 : do not daemonize * 1 : daemonize */ #define DAEMONIZE 1 /* size of the reception buffer which gets data from the serial line */ #define SIZE_BUF 256 /** * Prints debug messages to stderr if debug is wanted */ static void dbg(char *fmt, ...) { va_list args; if (DEBUG) { fflush(NULL); va_start(args, fmt); vfprintf(stderr, fmt, args); va_end(args); fprintf(stderr, "\n"); fflush(NULL); } return; } /** * Sends an AT command to the specified line and gets its result * Returns 0 on success * -1 on failure */ int send_at_command(int serial_fd, char *command) { char buf[SIZE_BUF]; int r; /* write the AT command to the serial line */ if (write(serial_fd, command, strlen(command)) <= 0) err(EXIT_FAILURE, "Cannot write to %s", SERIAL_PORT); /* wait a bit to allow the modem to rest */ sleep(1); /* read the result of the command from the modem */ memset(buf, 0, sizeof(buf)); r = read(serial_fd, buf, sizeof(buf)); if (r == -1) err(EXIT_FAILURE, "Cannot read %s", SERIAL_PORT); /* if there is no result from the modem, return failure */ if (r == 0) { dbg("%s\t: No response", command); return -1; } /* if we have a result and want debug info, strip CR & LF out from the output */ if (DEBUG) { int i; char bufp[SIZE_BUF]; memcpy(bufp, buf, sizeof(buf)); for(i=0; i<strlen(bufp); i++) { if (bufp[i] == '\r' || bufp[i] == '\n') bufp[i] = ' '; } dbg("%s\t: %s", command, bufp); } /* if the output shows "OK" return success */ if (strstr(buf, "OK\r") != NULL) { return 0; } return -1; } /** * Function raised by signal catching */ void signal_callback_handler(int signum) { return; } /** * Gets the major number of the driver device * Returns the major number on success * -1 on failure */ int get_major(char *driver) { FILE *fp; char *line = NULL; size_t len = 0; ssize_t read; char device[20]; int major = -1; /* open /proc/devices file */ if ((fp = fopen("/proc/devices", "r")) == NULL) err(EXIT_FAILURE, "Cannot open /proc/devices"); /* read the file line by line */ while ((major == -1) && (read = getline(&line, &len, fp)) != -1) { /* if the driver name string is found in the line, try to get the major */ if (strstr(line, driver) != NULL) { if (sscanf(line,"%d %s\n", &major, device) != 2) major = -1; } /* free the line before getting a new one */ if (line) { free(line); line = NULL; } } /* close /proc/devices file */ fclose(fp); return major; } /** * Creates nodes for the virtual TTYs * Returns the number of nodes created */ int make_nodes(int major, char *basename, int number_nodes) { int minor, created = 0; dev_t device; char node_name[15]; mode_t oldmask; /* set a new mask to get 666 mode and stores the old one */ oldmask = umask(0); for (minor=1; minor<number_nodes+1; minor++) { /* append the minor number to the base name */ sprintf(node_name, "%s%d", basename, minor); /* store a device info with major and minor */ device = makedev(major, minor); /* create the actual character node */ if (mknod(node_name, S_IFCHR | 0666, device) != 0) { warn("Cannot create %s", node_name); } else { created++; dbg("Created %s", node_name); } } /* revert the mask to the old one */ umask(oldmask); return created; } /** * Removes previously created TTY nodes * Returns nothing, it doesn't really matter if it fails */ void remove_nodes(char *basename, int number_nodes) { int node; char node_name[15]; for (node=1; node<number_nodes+1; node++) { /* append the minor number to the base name */ sprintf(node_name, "%s%d", basename, node); /* unlink the actual character node */ dbg("Removing %s", node_name); if (unlink(node_name) == -1) warn("Cannot remove %s", node_name); } return; } int main(void) { int serial_fd, major; struct termios tio; int ldisc = N_GSM0710; struct gsm_config gsm; char atcommand[40]; /* print global parameters */ dbg("SERIAL_PORT = %s", SERIAL_PORT); /* open the serial port */ serial_fd = open(SERIAL_PORT, O_RDWR | O_NOCTTY | O_NDELAY); if (serial_fd == -1) err(EXIT_FAILURE, "Cannot open %s", SERIAL_PORT); /* get the current attributes of the serial port */ if (tcgetattr(serial_fd, &tio) == -1) err(EXIT_FAILURE, "Cannot get line attributes"); /* set the new attrbiutes */ tio.c_iflag = 0; tio.c_oflag = 0; tio.c_cflag = CS8 | CREAD | CLOCAL; tio.c_cflag |= CRTSCTS; tio.c_lflag = 0; tio.c_cc[VMIN] = 1; tio.c_cc[VTIME] = 0; /* write the speed of the serial line */ if (cfsetospeed(&tio, LINE_SPEED) < 0 || cfsetispeed(&tio, LINE_SPEED) < 0) err(EXIT_FAILURE, "Cannot set line speed"); /* write the attributes */ if (tcsetattr(serial_fd, TCSANOW, &tio) == -1) err(EXIT_FAILURE, "Cannot set line attributes"); /** * Send AT commands to put the modem in CMUX mode. * This is vendor specific and should be changed * to fit your modem needs. * The following matches Quectel M95. */ if (send_at_command(serial_fd, "AT+IFC=2,2\r") == -1) errx(EXIT_FAILURE, "AT+IFC=2,2: bad response"); if (send_at_command(serial_fd, "AT+GMM\r") == -1) warnx("AT+GMM: bad response"); if (send_at_command(serial_fd, "AT\r") == -1) warnx("AT: bad response"); if (send_at_command(serial_fd, "AT+IPR=115200&w\r") == -1) errx(EXIT_FAILURE, "AT+IPR=115200&w: bad response"); sprintf(atcommand, "AT+CMUX=0,0,5,%d,10,3,30,10,2\r", MTU); if (send_at_command(serial_fd, atcommand) == -1) errx(EXIT_FAILURE, "Cannot enable modem CMUX"); /* use n_gsm line discipline */ sleep(2); if (ioctl(serial_fd, TIOCSETD, &ldisc) < 0) err(EXIT_FAILURE, "Cannot set line dicipline. Is 'n_gsm' module registred?"); /* get n_gsm configuration */ if (ioctl(serial_fd, GSMIOC_GETCONF, &gsm) < 0) err(EXIT_FAILURE, "Cannot get GSM multiplex parameters"); /* set and write new attributes */ gsm.initiator = 1; gsm.encapsulation = 0; gsm.mru = MTU; gsm.mtu = MTU; gsm.t1 = 10; gsm.n2 = 3; gsm.t2 = 30; gsm.t3 = 10; if (ioctl(serial_fd, GSMIOC_SETCONF, &gsm) < 0) err(EXIT_FAILURE, "Cannot set GSM multiplex parameters"); dbg("Line dicipline set"); /* create the virtual TTYs */ if (CREATE_NODES) { int created; if ((major = get_major(DRIVER_NAME)) < 0) errx(EXIT_FAILURE, "Cannot get major number"); if ((created = make_nodes(major, BASENAME_NODES, NUM_NODES)) < NUM_NODES) warnx("Cannot create all nodes, only %d/%d have been created.", created, NUM_NODES); } /* detach from the terminal if needed */ if (DAEMONIZE) { dbg("Going to background"); if (daemon(0,0) != 0) err(EXIT_FAILURE, "Cannot daemonize"); } /* wait to keep the line discipline enabled, wake it up with a signal */ signal(SIGINT, signal_callback_handler); signal(SIGTERM, signal_callback_handler); pause(); /* remove the created virtual TTYs */ if (CREATE_NODES) { remove_nodes(BASENAME_NODES, NUM_NODES); } /* close the serial line */ close(serial_fd); return EXIT_SUCCESS; }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 #ifndef _LINUX_GSMMUX_H #define _LINUX_GSMMUX_H struct gsm_config { unsigned int adaption; unsigned int encapsulation; unsigned int initiator; unsigned int t1; unsigned int t2; unsigned int t3; unsigned int n2; unsigned int mru; unsigned int mtu; unsigned int k; unsigned int i; unsigned int unused[8]; /* Padding for expansion without breaking stuff */ }; #define GSMIOC_GETCONF _IOR('G', 0, struct gsm_config) #define GSMIOC_SETCONF _IOW('G', 1, struct gsm_config) struct gsm_netconfig { unsigned int adaption; /* Adaption to use in network mode */ unsigned short protocol;/* Protocol to use - only ETH_P_IP supported */ unsigned short unused2; char if_name[IFNAMSIZ]; /* interface name format string */ __u8 unused[28]; /* For future use */ }; #define GSMIOC_ENABLE_NET _IOW('G', 2, struct gsm_netconfig) #define GSMIOC_DISABLE_NET _IO('G', 3) #endif
robert
