[General] how to reset multiplexing (CMUX) on sim800
robert@redcor.ch
Newbie level 1
Hi there,
I am using i sligthly modified c program I found on the net:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
* Cmux
* Enables GSM 0710 multiplex using n_gsm
* Copyright (C) 2013 - Rtone - Nicolas Le Manchet <nicolaslm@rtone.fr>
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <stdlib.h>
#include <stdio.h>
#include <stdarg.h>
#include <string.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include <termios.h>
#include <net/if.h>
#include <linux/types.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <err.h>
#include <signal.h>
* gsmmux.h provides n_gsm line dicipline structures and functions.
* It should be kept in sync with your kernel release.
#include "gsmmux.h"
/* n_gsm ioctl */
#ifndef N_GSM0710
# define N_GSM0710  21
#endif
/* attach a line discipline ioctl */
#ifndef TIOCSETD
# define TIOCSETD   0x5423
#endif
/* serial port of the modem */
#define SERIAL_PORT "/dev/ttyS1"
/* line speed */
#define LINE_SPEED  B115200
/* maximum transfert unit (MTU), value in bytes */
#define MTU 512
* whether or not to create virtual TTYs for the multiplex
* 0 : do not create
* 1 : create
#define CREATE_NODES    1
/* number of virtual TTYs to create (most modems can handle up to 4) */
#define NUM_NODES   4
/* name of the virtual TTYs to create */
#define BASENAME_NODES  "/dev/ttyGSM"
/* name of the driver, used to get the major number */
#define DRIVER_NAME "gsmtty"
* whether or not to print debug messages to stderr
* 0 : debug off
* 1 : debug on
#define DEBUG   1
* whether or not to detach the program from the terminal
* 0 : do not daemonize
* 1 : daemonize
#define DAEMONIZE   1
/* size of the reception buffer which gets data from the serial line */
#define SIZE_BUF    256
* Prints debug messages to stderr if debug is wanted
static void dbg(char *fmt, ...) {
va_list args;
if (DEBUG) {
fflush(NULL);
va_start(args, fmt);
vfprintf(stderr, fmt, args);
va_end(args);
fprintf(stderr, "\n");
fflush(NULL);
return;
* Sends an AT command to the specified line and gets its result
* Returns 0 on success
* -1 on failure
int send_at_command(int serial_fd, char *command) {
char buf[SIZE_BUF];
int r;
/* write the AT command to the serial line */
if (write(serial_fd, command, strlen(command)) <= 0)
err(EXIT_FAILURE, "Cannot write to %s", SERIAL_PORT);
/* wait a bit to allow the modem to rest */
sleep(1);
/* read the result of the command from the modem */
memset(buf, 0, sizeof(buf));
r = read(serial_fd, buf, sizeof(buf));
if (r == -1)
err(EXIT_FAILURE, "Cannot read %s", SERIAL_PORT);
/* if there is no result from the modem, return failure */
if (r == 0) {
dbg("%s\t: No response", command);
return -1;
/* if we have a result and want debug info, strip CR & LF out from the output */
if (DEBUG) {
int i;
char bufp[SIZE_BUF];
memcpy(bufp, buf, sizeof(buf));
for(i=0; i<strlen(bufp); i++) {
if (bufp[i] == '\r' || bufp[i] == '\n')
bufp[i] = ' ';
dbg("%s\t: %s", command, bufp);
/* if the output shows "OK" return success */
if (strstr(buf, "OK\r") != NULL) {
return 0;
return -1;
* Function raised by signal catching
void signal_callback_handler(int signum) {
return;
* Gets the major number of the driver device
* Returns the major number on success
* -1 on failure
int get_major(char *driver) {
FILE *fp;
char *line = NULL;
size_t len = 0;
ssize_t read;
char device[20];
int major = -1;
/* open /proc/devices file */
if ((fp = fopen("/proc/devices", "r")) == NULL)
err(EXIT_FAILURE, "Cannot open /proc/devices");
/* read the file line by line */
while ((major == -1) && (read = getline(&line, &len, fp)) != -1) {
/* if the driver name string is found in the line, try to get the major */
if (strstr(line, driver) != NULL) {
if (sscanf(line,"%d %s\n", &major, device) != 2)
major = -1;
/* free the line before getting a new one */
if (line) {
free(line);
line = NULL;
/* close /proc/devices file */
fclose(fp);
return major;
* Creates nodes for the virtual TTYs
* Returns the number of nodes created
int make_nodes(int major, char *basename, int number_nodes) {
int minor, created = 0;
dev_t device;
char node_name[15];
mode_t oldmask;
/* set a new mask to get 666 mode and stores the old one */
oldmask = umask(0);
for (minor=1; minor<number_nodes+1; minor++) {
/* append the minor number to the base name */
sprintf(node_name, "%s%d", basename, minor);
/* store a device info with major and minor */
device = makedev(major, minor);
/* create the actual character node */
if (mknod(node_name, S_IFCHR | 0666, device) != 0) {
warn("Cannot create %s", node_name);
} else {
created++;
dbg("Created %s", node_name);
/* revert the mask to the old one */
umask(oldmask);
return created;
* Removes previously created TTY nodes
* Returns nothing, it doesn't really matter if it fails
void remove_nodes(char *basename, int number_nodes) {
int node;
char node_name[15];
for (node=1; node<number_nodes+1; node++) {
sprintf(node_name, "%s%d", basename, node);
/* unlink the actual character node */
dbg("Removing %s", node_name);
if (unlink(node_name) == -1)
warn("Cannot remove %s", node_name);
return;
int main(void) {
int serial_fd, major;
struct termios tio;
int ldisc = N_GSM0710;
struct gsm_config gsm;
char atcommand[40];
/* print global parameters */
dbg("SERIAL_PORT = %s", SERIAL_PORT);
/* open the serial port */
serial_fd = open(SERIAL_PORT, O_RDWR | O_NOCTTY | O_NDELAY);
if (serial_fd == -1)
err(EXIT_FAILURE, "Cannot open %s", SERIAL_PORT);
/* get the current attributes of the serial port */
if (tcgetattr(serial_fd, &tio) == -1)
err(EXIT_FAILURE, "Cannot get line attributes");
/* set the new attrbiutes */
tio.c_iflag = 0;
tio.c_oflag = 0;
tio.c_cflag = CS8 | CREAD | CLOCAL;
tio.c_cflag |= CRTSCTS;
tio.c_lflag = 0;
tio.c_cc[VMIN] = 1;
tio.c_cc[VTIME] = 0;
/* write the speed of the serial line */
if (cfsetospeed(&tio, LINE_SPEED) < 0 || cfsetispeed(&tio, LINE_SPEED) < 0)
err(EXIT_FAILURE, "Cannot set line speed");
/* write the attributes */
if (tcsetattr(serial_fd, TCSANOW, &tio) == -1)
err(EXIT_FAILURE, "Cannot set line attributes");
* Send AT commands to put the modem in CMUX mode.
* This is vendor specific and should be changed
* to fit your modem needs.
* The following matches Quectel M95.
if (send_at_command(serial_fd, "AT+IFC=2,2\r") == -1)
errx(EXIT_FAILURE, "AT+IFC=2,2: bad response");
if (send_at_command(serial_fd, "AT+GMM\r") == -1)
warnx("AT+GMM: bad response");
if (send_at_command(serial_fd, "AT\r") == -1)
warnx("AT: bad response");
if (send_at_command(serial_fd, "AT+IPR=115200&w\r") == -1)
errx(EXIT_FAILURE, "AT+IPR=115200&w: bad response");
sprintf(atcommand, "AT+CMUX=0,0,5,%d,10,3,30,10,2\r", MTU);
if (send_at_command(serial_fd, atcommand) == -1)
errx(EXIT_FAILURE, "Cannot enable modem CMUX");
/* use n_gsm line discipline */
sleep(2);
if (ioctl(serial_fd, TIOCSETD, &ldisc) < 0)
err(EXIT_FAILURE, "Cannot set line dicipline. Is 'n_gsm' module registred?");
/* get n_gsm configuration */
if (ioctl(serial_fd, GSMIOC_GETCONF, &gsm) < 0)
err(EXIT_FAILURE, "Cannot get GSM multiplex parameters");
/* set and write new attributes */
gsm.initiator = 1;
gsm.encapsulation = 0;
gsm.mru = MTU;
gsm.mtu = MTU;
gsm.t1 = 10;
gsm.n2 = 3;
gsm.t2 = 30;
gsm.t3 = 10;
if (ioctl(serial_fd, GSMIOC_SETCONF, &gsm) < 0)
err(EXIT_FAILURE, "Cannot set GSM multiplex parameters");
dbg("Line dicipline set");
/* create the virtual TTYs */
if (CREATE_NODES) {
int created;
if ((major = get_major(DRIVER_NAME)) < 0)
errx(EXIT_FAILURE, "Cannot get major number");
if ((created = make_nodes(major, BASENAME_NODES, NUM_NODES)) < NUM_NODES)
warnx("Cannot create all nodes, only %d/%d have been created.", created, NUM_NODES);
/* detach from the terminal if needed */
if (DAEMONIZE) {
dbg("Going to background");
if (daemon(0,0) != 0)
err(EXIT_FAILURE, "Cannot daemonize");
/* wait to keep the line discipline enabled, wake it up with a signal */
signal(SIGINT, signal_callback_handler);
signal(SIGTERM, signal_callback_handler);
pause();
/* remove the created virtual TTYs */
if (CREATE_NODES) {
remove_nodes(BASENAME_NODES, NUM_NODES);
/* close the serial line */
close(serial_fd);
return EXIT_SUCCESS;
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
#ifndef _LINUX_GSMMUX_H
#define _LINUX_GSMMUX_H
struct gsm_config
unsigned int adaption;
unsigned int encapsulation;
unsigned int initiator;
unsigned int t1;
unsigned int t2;
unsigned int t3;
unsigned int n2;
unsigned int mru;
unsigned int mtu;
unsigned int k;
unsigned int i;
unsigned int unused[8]; /* Padding for expansion without
breaking stuff */
#define GSMIOC_GETCONF  _IOR('G', 0, struct gsm_config)
#define GSMIOC_SETCONF  _IOW('G', 1, struct gsm_config)
struct gsm_netconfig {
unsigned int adaption; /* Adaption to use in network mode */
unsigned short protocol;/* Protocol to use - only ETH_P_IP supported */
unsigned short unused2;
char if_name[IFNAMSIZ]; /* interface name format string */
__u8 unused[28]; /* For future use */
#define GSMIOC_ENABLE_NET _IOW('G', 2, struct gsm_netconfig)
#define GSMIOC_DISABLE_NET _IO('G', 3)
#endif
Original GitHub Repository
Sometimes I need to reinitialize the modem, however it seems to be blocked.
How can I reset it, preferably using AT commands to a non cmux configuration.
thanks for your time
robert
