How to reset a STx5119 board by software ? (ST20 OS)
Ahmed Samieh
Junior Member level 1
Egypt
hello all
i'm new in ST20 OS so i have some problems
we are using STx5119 set-top box decoder
and i want to reset the board in software
what is the reset vector or is there known function to do this task ?
thanx
Ahmed Samieh
Re: Software reset
I do not know exactly about your OS or board, but this is how I do it on my ARM board using Velos or ucos-ii. I just branch to the start of the code. I will be more helpful, if I can look on the source codes.
BR,
Amr Ali.
Software reset
thanx Amr
i just want to know the start of the code !!!
i tried to call the main function but no way
the bootloader start befor my os main !!!!!!!!
i don't know what is that :(
about the source, it is larger than what you think to trace it
about 470 MB
thanx
Ahmed Samieh
Re: Software reset
AA,
1- What does your software consists off? I mean the bootloader + OS + application statically linked in one file or not.
2- If every thing is in a single image, check ur linker settings for the code entry, find it, then invoke a branch instruction to it whenever a software reset is required.
BR,
Amr Ali.
Re: Software reset
Do you have a watchdog on that board? If you do, just start watchdog, and presto you will have a reset, which will restart your board.
Software reset
thanx cfant for your helpful replay, i will try it this idea in the work
Ahmed Samieh
