nansri84
- Joined
- Nov 18, 2013
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 50
What is Vbat? And can I assume that 10K goes to ground? And you realize that if Vbat is less than about 3.6 volts, it's going to be sucking current through the parasitic diode of the MOSFET, right? And the load is connected to the drain?
I agree with barry that the battery is potentially charged from 4.2V node. Depending on the battery type this might conflict with safety regulations.
Presumed that you don't need to cut-off the battery supply, you'll usually flip drain and source terminals.
But for a full assessment, battery type, main voltage supply range and minimal RAM supply must be known. As a generally comment, for battery and RTC backup only, I would try to come along with a passive diode switch.
Now I'm totally confused. First of all, that is not the schematic symbol for a P-channel MOSFET; that's the schematic symbol for a box with 6 terminals.The battery type is 3.7V/890mAh Li-on battery. The main supply is max 36V and the operating voltage is 4.2V.
