How to reduce 120hz harmonics?
ahgu
Full Member level 3
My TL074 OPAMP has gain of 40dB, and I see 10-20mV of 120hz, 240hz harmonics at the output. I think my ground noise is at 0.1mV, the LDO says it has 30-40uV RMS. Is it a good ground plane with noise of 0.1mV? I think I did the layout pretty good with ground plane and signal separation.
But the 120hz harmonics is a little too high and shows up on the speaker, how can I remove or reduce the harmonics?
And is it possible to reduce the ground noise even lower?
thanks
ahgu
brmadhukar
Advanced Member level 3
India
Hi
Check the PS filter. Just a capacitor might do the trick.
post your circuit and layout for details.
madhukar
flatulent
Advanced Member level 5
Middle Earth
check for source
You can do a few experiments to find where it is coming from. First disconnect the input to the amplifier and short it to ground. Does the hum go away? Power the circuit from a laboratory quality power supply. Does the hum go away?
artem
Turkey
If you use only 1 opamp input try to insert blocking capasitor on other input with enough capasity to filter 120 Hz .
