How to read asm file from hex file?
zhi_yi
Full Member level 4
hi there, i have a question, if i had write a hex file into a microcontroller, can i read the asm file from the microcontroller?
thank you very much :)
ful babu
Full Member level 3
Singapore
Re: read asm from hex
look at this
and use search in the forum...
regards
asahin11
Member level 3
Hi zhi_yi,
Try icprog pic programmer.
regrads,
solom
Newbie level 1
EGYPT
if you use 8051 you can use tsemlutor it can disassamply
Tommy Williams
you can use programmer to read program from microcontroller and use decompiler to decomplle the hex to readable program.
syed intisar haider
Member level 2
read asm from hex
hi
h r u ?
use icprog pic u will get ur ans
and try to search the fourms contents in this regard
take care
idlebrain
You can view dis assembled code in any debugger software, But you may not be able to save assembly file.
You need a tool called dis assembler. I am having DIS51 (dis assembler for MCS51). If you are using 51 series of micro, I can upload. You may also download from net. But I am not sure how much useful is the generated assembly code.
cheers
idlebrain
