adnan_merter
Full Member level 3
- Joined
- Jan 23, 2008
- Messages
- 160
- Helped
- 6
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- The most beautiful city of the world
- Activity points
- 2,526
hi everybody,
i need to know how i can receive a string from rs232,
i mean (and already know the gets() and get_string() functions) i am sending a bunch of string without no time delay from pc to pic
and i need to read them line by line and compare each line whether it contains particular character and if it contains, pic should send it to the other pc
i already tried gets() function and it doesnt work,
here is my function, i have written to get each line seperately.
here is main.h
(i didnt work on the compare section yet)
i am using pic18f2550 and ccs c compiler, when i tried to run this code, it reads first line and it stops, Readline() function starts for a second line but it doesnt read the second line, everything looks fine but something is definately wrong.
waiting for your advices thanks
#include "main.h"
#include "LCD.c"
#include <string.h>
#use rs232(baud=9600,parity=N,xmit=PIN_C1,rcv=PIN_C0,bits=8,STOP=1, stream = PC2)
#use rs232(baud=300,parity=E,xmit=PIN_C6,rcv=PIN_C7,bits=7,STOP=1, stream = PC1)
static unsigned char ReceivedMsg[25];
static unsigned int1 endoftransmission = FALSE;
void Readline();
void main()
setup_adc_ports(NO_ANALOGS|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_ccp1(CCP_OFF);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
lcd_init();
lcd_putc('\f');
lcd_gotoxy(1,1);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
fprintf(PC2,"WAITING FOR THE NECCESSARY VALUES");
while(1)
while(!endoftransmission){
Readline();
fputs(ReceivedMsg,PC2);
void Readline()
memset(ReceivedMsg,0,sizeof(ReceivedMsg));
unsigned char MsgChar;
int k=0;
while(MsgChar != 0x0A)//getch() until LF char received
MsgChar = fgetc(PC1);
if(MsgChr=='!')
endoftransmission=TRUE;
ReceivedMsg[k] = MsgChar;
k++;
here is main.h
#include <18F2550.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES HSPLL //High Speed Crystal/Resonator with PLL enabled
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOBROWNOUT //No brownout reset
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPUT //No Power Up Timer
#FUSES NOCPD //No EE protection
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES IESO //Internal External Switch Over mode enabled
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC //configuration not registers write protected
#FUSES NOWRTB //Boot block not write protected
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#FUSES NOCPB //No Boot Block code protection
#FUSES MCLR //Master Clear pin enabled
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL5 //Divide By 5(20MHz oscillator input)
#FUSES CPUDIV1 //System Clock by 1
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#use delay(clock=48000000)
