How to quantize a number for DSP filter implement ?
EDA_hg81
Advanced Member level 2
Thanks.
The numbers are automatically quantized in some way when you try to use them. Even if you use PI on your calculator it is quantized!
Serious now : for a 12 bit implementation, the quantization happens when you try to grab the signal with a 12 bit AD converter. If you however want to use only 8 bits, you chunk off 4 extra bits with a right shift operation.
Stefaan
    EDA_hg81
but in polyphase scaler the fractional part need to be quantized,
ho to do this?
thanks.
