j_dennisan2005
Newbie level 1
how to program mplab using pic16f84a
i need some help from u my dear. actually i doing my final year project. my project title is Auto Door Access by Using Fingerprint. The door is controlled by PIC16F84A IC. Now, i need to program that IC. Can u do a favour to send me the source code in Assembly language to program the IC. I using MPLAB to build the coding to convert to Hex code and to program the hex code into PIC16F84A IC. To program the hex code into PIC IC, i using ICPROG software. The source code should do when the IC receive signal 0 input from computer serial port, then the IC should activate. so it's can produce the output to magnetic lock to open the door. when receive signal 1 input from computer serial port, then the IC should be deactivate. so, no output produce to magnetic lock to open the door. that's mean the door still lock. one more thing, can u tell me step by step to build the assembly coding in MPLAB and program the IC by using ICPROG software. Plz help me by sending me the source code as soon as possible. thanks a lot. bye. take care.,\][/url][/list][/quote][/u][/i]
