how to program atmel microcontroller using usbasp
brian25
Member level 2
Member level 2
how to program atmel microcontroller using usbasp but i want to use arduino IDE to make codes?
tnx
easy 1st find the .hex file .... you will need extreem burner software. locate the .hex file and burn it.....
you will get the hex file location when you build your project... lots of line is comming find the path ends with .hex
Mohammed Ismail
Reactions: brian25
    brian25
