info_req
Member level 5
Dear,
I am trying to program Atmega128L Micro-controller but I could not be successful.
I tried it using JTAG programmer JTAGICE mk2, it programmed but later on no response from microcntroller. Programmer reads 5.1 voltage from the target board that i designed myself, but it doesn't read microcntroller device ID and donot program it. Then i tried it on ISP Programmer where it is also not programming. The same programmer is programming Atmega8 Microconroller.
I checked this circuit with Oscilloscope there PEN Low, Reset goes low, SCK clocks, MOSI also toggles repetitively but there is no MISO output.
Please tell if i am wrong or missing something ????
If you have any working circuit and programming software then plz share.
Regards,
Regards,
