[51] How to program AT89c51?
Narendra1190
Member level 2
Member level 2
hi,
I bought an AT89c51 dev. board from below link.
I read some forum about interfacing RS232 with MCU for serial communication.I'm having USB to serial converter(DB9) which i used to connect my laptop and Dev. board.
I dont know how to burn hex file into AT89c51. Is it possible to load program through RS232?
no.sir, which programmer software i have to use to burn hex file on AT89c51 n how i can do tht?
Every hardware has its own supported software and without it you can't do anything with the hardware....for example i am using the genius g540 programmer and it has a software in which i can load a hex and can test ICs...
You can search the software for your development board on internet
