Which IDE you are using. you meant that you got controller or complete KIT. If you get complete kit then you would also get sample code examples with that. or else you need to go through the data sheet and program the controller.
I get not the Kit but IC with QFN48 Packaging.It should be programmed like other MCU. I don't Know how it can be program and Programming Boards available.
I have read Texas Instruments Flash Programmer User Manual and 8051 MCU in CC2510 can be programmed using SPI-like two-wire interface consisting of the bi-directional Debug Data (P2_1) and Debug Clock (P2_2) input pin. I have ez430-F2013 development tool that can program device using two wire interface called spybi-wire. Can i use this to tool to program cc2510?
