How to print out the design rules in PADS
BOPO
Newbie level 1
Is there a easy way to print out the design rules in pads..ie clearance rules and individual net rules..thanks
Re: DESIGN RULES IN PADS
to print the design rule u can only use print scrin option .
nikhil
You can export the ASCII files by only selecting the rules.It will contain all set of rules that are defined & this can be printed
You can generate the design rule's report from any of the hierarchy which you have set, by selecting report button, then click ok.
All rules will be in a notepad.
You can use vb script to get the report.They already have a standard format,jus look into it befor proceeding.....
hope this will help u.
Regards
Ramesh
By using the report option you can try to get the information.
-Rajkumar
